I want to run two entities through Swiss Things: 1.) a pedal board of stomp boxes, and 2.) a POD HD400. They each have their own graces, and can be amazing when combined (since you're essentially stacking effects exponentially if you desire; great for some intriguing sonic combinations, plus, the HD400 has a wah-expression pedal already built in).
Right now I've got the pedal board going into the POD HD400, and when--say, between songs--I want to go with only the pedal board boxes, it's awkward and imprecise (switch to a sort of dry channel in the POD). I should be able to just run the stomp boxes as one FX loop into Swiss Things, and run the POD HD400 as the other (#2) FX loop in Swiss Things.... I think.
Has anyone else done this? I haven't yet purchased a Swiss Things, since if it can't do what I'm asking about, there's no need.
Thanks in advance.
Running Line6 POD HD400 as an FX Loop in Swiss Things?
Moderator: earthdevice
EstebanBlanco
- uncommitted
- dandy13
Re: Running Line6 POD HD400 as an FX Loop in Swiss Things?
Yes you can do that with Swiss things
EstebanBlanco
- uncommitted
Thanks, @dandy13.
