Cheap Chinese Laser Engravers are Fun
culturejam
Post by culturejam »
Been having fun with an Eleksmaker A5 laser engraver. You can get these on various Chinese sites (BangGood, DealBest, etc) for about $150 - $175 if you get a coupon code. I went with the 2.5W laser head, but there are several options for wattage.
I mainly got it to see if I could make it useful for engraving powdercoated pedal boxes. I'm glad to report that it works pretty well for that application. :joy:
A couple passes gets it down 95% of the way to the bare metal. And then some 90% isopropyl and a toothbrush gets you another 4%. There a tiny bit of material left over which requires some scraping (dental pick) to remove, but it also kind a looks cool as is (sort of "relic" or oxidized).
There's still some work left to do to get the process optimized and tightened up, but I'm really pleased with the results so far.
Some pics:
Laser in action (here I was testing the feasibility of cutting through painter's tape on a bare box to use as a paint mask):
Powdercoated box, fresh off the laser (no cleanup):
Same box, after cleanup (took about 5 minutes):
Disclaimer #3: I do sporadic, infrequent contract work for Black Arts Toneworks
Check out my photo gear on the cheap site: Tight Camera
Re: Cheap Chinese Laser Engravers are Fun
Looks pretty good.
I would worry about that last 1%. Adds charm. :cool:
BetterOffShred
Post by BetterOffShred »
culturejam wrote:There a tiny bit of material left over which requires some scraping (dental pick) to remove, but it also kind a looks cool as is (sort of "relic" or oxidized).
I think it looks dope man. That's a pretty sweet setup!
MechaGodzilla
Post by MechaGodzilla »
:drool: :love:
multi_s
Post by multi_s »
nice.
my friend use one of these style deals to try the inverse, curing powder to the point that its tacky, blowing off the excess uncured powder, then heating the whole case up to set what remains (the text etc).
culturejam
multi_s wrote:nice.
Now *that* is an interesting idea. :thumb:
Does it actually work?
multi_s
Post by multi_s »
according to him it works but im not sure how long you need to heat the powder for it to cure, you would probably have to experiment. he was using 1.5watt laser though iirc so same ballpark as you. i mean if you can blast off teh powder than you should have more than enough power to partially cure it imho.
crudely the same concept as a laser printer though no? (:
culturejam
multi_s wrote:crudely the same concept as a laser printer though no? (:
Yeah, definitely. My biggest concern would be how to handle keeping the powder on the enclosure while etching. Usually you want to have "air assist" (ie, some kind of positive pressure air flowing across the etching surface) and that might move the powder.
multi_s
Post by multi_s »
ya good point but my guess is you only need a low power density on the paint to cure it somewhat, so air assist is not an issue really. from what i understand air assist is a means to get a bit more out of your laser and or get cleaner crisper edges when cutting dense materials like steel etc/ longer laser life due to more efficient use of power etc etc... definitely not an expert though.
i will see if he has any pictures of his results though and post them here.
culturejam
Air assist clears the smoke out of the way so it doesn't block/diffuse the laser beam. It also helps with cooling the substrate so it doesn't catch on fire.
multi_s
Post by multi_s »
ah i was imagining more like nitrogen injected at the laser beam to help cut steel plate or qqc when you said "air assist". like they are talking about here:
http://www.thefabricator.com/article/la ... er-cutting
culturejam
At the hobby level, it's really just an air pump or fan that keeps the temp down and smoke clear. It might mean something different on an industrial level.
Dr. Sherman Sticks M.D.
man this looks so cool. pardon my newb but what type of software do u use for something like this?
for making the designs and for "transferring" them (sorry can't think of the right phrasing right now)
is it vectors? like illustrator or more like cad?
culturejam
Dr. Sherman Sticks M.D. wrote:man this looks so cool. pardon my newb but what type of software do u use for something like this?
Yeah, basically Illustrator or InkScape or whatever does vector art. But you can also do photo etching, but it takes a bit more setup. Still working that out, but I have other people do amazing stuff that is photo quality. But like, not on pedal boxes. On wood and slate and whatnot.
awesome i can get by on illustrator
so then like how do u get your designs from the vector art to the engraver?
