Hey guys, this is the new, retooled version of the FrantaBit. Here's what's new:
- A built-in expression attenuator knob allows you to dial in the range of expression sweep.
- Improved expression response: in all modes, the expression value is now added to the on-board knob you're controlling, rather than just taking over control from the knob. This means you can set the exact minimum and maximum values to sweep through, and in "+" mode, even set different ranges of sweep for Samples and Bits, to very finely tune your sound.
The interface remains intuitive, so no hidden menus or special startup routines are necessary to set up the expression control.
- Low-noise, low-distortion active components provide a baseline of excellent audio fidelity, which you can then mangle to your heart's content.
https://ironether.com/shop/
