passive mixer, changed some stuff, doesn't work, help?!
sp3k
Post by sp3k »
I need something to connect more then my guitar to my pedals at the same time.
Will this passive mixer work? will i lose to much sound from the guitar?
Re: passive mixer, will this work?
I think it would work fine, but it depends on the application. You wouldn't lose much if anything from the guitar, cause it's not what's going through the mix. The Input1 and 2 are where you would perceive loss. What are you going to be running into those jacks?
sp3k
Post by sp3k »
input 1 is for a casio keybord i have, it has way more volume then my guitar, so that's why there's a volume pot for it. The second input is for a Peyote space explorer i'm building, thanks to another topic in here :)
sp3k
Post by sp3k »
I changed the design a bit, it doesn't work. Probably some ground stuff is wrong.
Help!
greyscales
Re: passive mixer, changed some stuff, doesn't work, help?!
Post by greyscales »
Looks like it would work to me. You shouldn't be losing any signal from your guitar since there's no resistance in its signal path.
Pollinator95
Post by Pollinator95 »
That should work, just make sure you didn't get sleeve/tip wrong and shunt it all to ground!
What's wrong exactly? Do you get guitar but no In 2, nothing, etc?
"Thin and lifeless like a Happy meal." - Rob Chappers, 2011
behndy wrote: i imagine all these shoddy spice racks littering heaven that Gawd gets pissed at you if you talk poo about 'cause "MAH BOI DEED THAHT.".
McSpunckle
Post by McSpunckle »
In your diagram, the sleeves and tips of the jacks are backwards. Maybe that's it!
Pollinator95
Hadn't noticed that. :facepalm: I have a little picture of a jack with "This is the tip. It goes to..." that I always refer to when wiring up because I always forget.
MrMurderMittens
Post by MrMurderMittens »
I want to put an analog VU meter on my pedals voltage sag/starve pot. Need help!
Pollinator95
How many threads have you posted this in?! Just start a new one. Anyway, I answered in the "Can I measure your fuzz" one.
