DOD/Black Arts Toneworks Boneshaker Distortion
- BitchPudding
Re: DOD/Black Arts Toneworks Boneshaker Distortion
is it always in stereo like that or do you have the option to run it mono?
YO YO ITS YA BOI
- DRodriguez
I use the fewtility one to downmix the three channels to mono, when running through the shake shack. The actual guitar has a standard quarter inch jack and a standard toggle between the three neck pickups and a tele sized p90 bridge
- alexsga
These are fifty bucks again
- Jwar
- Cosmic of BILF
Your moms 50 bucks.alexsga wrote:These are fifty bucks again
I'm sorry.
-JWAR
-JWAR
- BitchPudding
Is your boner sorry?
YO YO ITS YA BOI
- codetocontra
Sorry about your mother's boner.
- mathias
What do these sound like with the gain down? I didn't find many demos with really low gain settings.
I'm wondering whether this can replace my little Klone pedal (which doesn't play well on a daisy chain..) for that Tele twang lead sound and boosting other pedals, plus being able to dial in that EQ!
Edit: am I wrong in the assumption I had that this is just the DOD-mass-produced version of the Black Forest? I may have just been assuming they were the same from the controls...
ILF Equipped
- jrfox92
Personally, I'm not really crazy about the gain control. It has a very steep taper (so most of the gain is at the end of the sweep).mathias wrote:What do these sound like with the gain down? I didn't find many demos with really low gain settings.
However, it sounds great if you use your guitar's volume to control the gain.
Also, doing the "cap mod" to the depth control (where you flip two of the caps so that the adjustment is a lot more noticeable) is a really nice way of adjusting the gain, too.
Yeah, they're not even remotely related.mathias wrote:Edit: am I wrong in the assumption I had that this is just the DOD-mass-produced version of the Black Forest? I may have just been assuming they were the same from the controls...
The Black Forest is a Colorsound Overdriver (which is transistor based) while the Boneshaker uses Op-Amps (it's kinda comparable, in design, to a Voodoo Labs overdrive, actually).
Since I always forget:
SPOILER : show
- mathias
Thanks! The Boneshaker might be something I'll try in the future, but I will continue to keep an eye out for a used Black Forest.
ILF Equipped
- John
[img]http://ilovefuzz.com/download/file.php?avatar=7077_1487566711.gif[/img] codetocontra wrote:Sorry about your mother's boner.
- ck3
http://www.harmanaudio.com/DOD-BONESHAKER.html
I impulsively ordered another one.
- scabiosa
I guess this is not really meant to be a high gainer. it's all about tone
boost the amp with it and create the tone you always had in mind
like it for that
x
like it for that
x
- Inconuucl
It's one of those "push an amp gainstage for maximum hair" type of pedals more than anything.
- BetterOffShred
My man! $40 on reverb.. Yeah I'll get one this Friday.
- ck3
Starved voltage can open a whole new dimension of luscious, fuzzy drive tones with the Boneshaker, especially when the bass frequency clipping is set in its upper range.
