Name help please!
unusual effects from London <raingerfx.com> <FB> <Tw> <IG>
Moderator: D-Rainger
D-Rainger
Name help please!
Post by D-Rainger »
It's a digital delay mini-pedal!
Has 'level', 'feedback', and 'speed' controls.
Comes with Igor foot controller - which either controls the delay speed, amount of feedback, or as a 'send to' control (guitar is totally dry until Igor is pressed, which sends signal to the delay line which then echoes away - while you can carry on playing dry :!!!: ).
The echo itself has a slight top-end roll-off, and some low-end roll-off too - which I think sounds totally brilliant!!! :!!!: :!!!: Reminds me of dub echoes (plus with the send and other controls...). As it spins away it sounds somehow.... like music......
Why does no-one seem to care about low-end roll-off in delay pedals?!! It totally rules!!!! :!!!: :!!!: :!!!:
This pedal isn't a looper pedal - trying to faithfully reproduce the original sound. With delay I either want dubby weirdness/sound bending as it spins away, or just some 'echo-ness' while I'm playing - ie get out of the way, frequency-wise!!!!
It's not trying to sound 'analogue'. It's a digital delay, sounds gorgeous, about 600ms max, deeply cute, oscillates lovely, tiny enclosure, tiny price etc.
Needs a name.
Re: Name help please!
No idea for a name, but I wanna hear some sound clips. Please!
lordgalvar
Post by lordgalvar »
It sounds like an awesome little pedal! Is it the same size as the Dwarf and Invader? This sounds awesome though. Yes, clips, please.
Compactlicator, Invasive Replicant, Chrono Transponder, Dubtronic Beacon....I don't know, I tried based on your other pedals and tried to keep it the realm of the 50-60s sci-fi theme.
-Ring Mods!
"I make you chocolate"
D-Rainger in D-D-Dub
Pepe
Post by Pepe »
DD-3.1 ;)
D-Rainger wrote:Why does no-one seem to care about low-end roll-off in delay pedals?!! It totally rules!!!! :!!!: :!!!: :!!!:
The KORG ToneWorks 301dl has both HI and LOW cutoff. I love it for that feature.
Pepe at YouTube and Instagram
D-Rainger
Post by D-Rainger »
Hey guys thanks! Lots of encouragements here - and names got me thinking...
Yes, same size as Dwarf and ASI, sockets on the end, switches at the bottom end, input and output knobs too - for keeping the input not too hot (LED level indicator) and for boosting the overall output back up to mad levels....
5 knobs in total - mini black ones, like ASI.
Will post soundclips asap.
Pepe
Post by Pepe »
"Again please?"
lordgalvar
This thing keeps sounding more awesome. The send-to mode sounds like something I have wante for a while. Low-end roll off is something that is good too.
More thoughts:
La Retraso Filtrada or just El Retraso
ReRetrograder
Electro Replicant
-Ring Mods!
oldangelmidnight
Post by oldangelmidnight »
Igor for dub feedback control will be fantastic.
In tribute to some awesome Dub, maybe Doctor Freakenstein Meets Igor at Dub Station. Or maybe that should be the name of a dual pedal with a Freakenstein and this delay housed together...
Dandolin
Post by Dandolin »
First--this sounds eleventy-one kinds of aws-sauce! :!!!:
But..help me understand. :erm:
Igor press would trigger a delay cycle, right, which could mean one Igor press=numerous evenly spaced repeats starting when you press? I guess you could also adjust the feedback so you get just one repeat in the cycle and pressing the Igor can trigger sorta instant repeats to the rhythm of your press? Can you, I dunno, override/flood the buffer (that phrase soundz kewl, but I'm not sure it means what I want to say), erm basically trigger new repeats in the midst of a repeat cycle such that the result would sound glitchy?
Love the frequency loss idea; when I first started to pay attention to delay at all, that was the sound that caught my attention....
Erm...Brixton Inshoreckshun, Dub Inshoreckshun, Dub Nation, Dub Dwarf.
This sounds amazing! I love the sound of high-pass filters on delays and reverbs, and having a cascade of delay that's only what you get when you press the switch and then it's dry again? That sounds incredible (I think I understood right?). This is super duper on my radar.
No ideas on a name unfortunately, just encouragement! :thumb:
neonblack
Post by neonblack »
Reanimated Brain
Sort of goes with the Igor delay trigger idea, like its the bolt of lightning that restarts the brain.
I want this bad.
Dandolin
Post by Dandolin »
neonblack wrote:Reanimated Brain
:lol: :thumb:
lordgalvar
This pedal has me really excited. I remember reading elsewhere that the Igor can be subsituted for other CV sources, correct?
This thing can be as glitchy as you could imagine with different CV sources, I suppose. Also, controlled spikes of oscillation!
-Ring Mods!
D-Rainger
Post by D-Rainger »
Dandolin wrote:First--this sounds eleventy-one kinds of aws-sauce! :!!!:
An Igor press sends to the delay circuit - but it's the nature of Igor that the press isn't 'hard-edged'.... It has the same attack as stamping down on an expression pedal.
Yes - with one repeat you could re-send in some sort of rhythm. You could actually use it as a looper - play something with Igor pressed, let that loop away, play dry over the top of it, maybe add another note to the echo.... But over about ten repeats the sound starts to change, gets interestingly melted... Then new repeats added to it would sound 'newer'. Also it isn't an amazingly long delay time. Did I say 600ms? Now I'm not sure if it'd be that much, but it'd be enough to be useful in songs (of varying speeds). Like I said, it's not meant to be a looper.
But right now, I'm dealing with all kinds of problems with it. I'll get there, but electronics is very unforgiving - until it suddenly works, and then it's a big rush :!!!: :!!!:
To tell the truth, I was never aware of the bass-cut aspect, just while I was working on this started wondering why it seemed to sound extra cool.... :cool:
'Dub Dwarf' is pretty neat....
BTW when this is out I gotta make baseplates to attach two RFX mini-pedals together.... Dwarf and a delay together side-by-side would be about as wide as a regular 'Boss' pedal (but of course no side sockets!). And the footswitches would be about 4cm apart! Easily switch them on together, and both with Igors. A little patch lead joining them.
It'd be possible to switch them individually if you weren't drunk.
Offer a wider spaced baseplate for when you were....
Or a small trained monkey to switch them individually for you.
Do you know Danny Gatton had a human being to turn his effects on and off for him?! (usually a leslie cabinet).
I'd have been quite happy doing that for him.
