Hi i'm needing some help with this.
I bought an MZ-2 on reverb with the mode knob not working. It's an analog pcb sandwiched to a digital pcb. The mode knob is stuck in drive function no matter where i set it. I poked every solder joint with a chop stick and couldn't get even a whisper of the chorus and delay/doubler signal. Can't find a loose or cold solder joint anywhere. I was once able to fix an RV3 with a non functioning mode knob by flowing some solder where the mode knob connected to the board so I had hope.. but this issue is different in behavior.
Really hoping to get this working. I'm thinking now it could be the connection between the digital pcb and the outputs but idk.
Here are the MZ-2 service notes if that helps.
https://www.audioservicemanuals.com/b/b ... vice-notes
Thanks
