So about a year ago I started working on a couple junker/project guitars, but gave up due to construction issues... I'm trying again, but not having any success. The problem is that I was huge idiot and gorilla-glued the tune-o-matic thimbles into the bodies because I drilled the holes slightly too large. Now I can't figure out if it's possible to get them out. I just tried using a bolt to pull them out, and only succeeded in starting to separate the guitar body midway
Any ideas, or am I fucked?
The other body mayyyyy yet work, but I have to figure out how to ground it, since I glued the thimbles before inserting the ground wire. I'm going to try a ghetto ground-to-bridge rig, but I have no idea if where I placed the bridge thimbles will allow for good intonation or anything
