by joujimiichi » Mon Mar 25, 2013 12:58 pm
Not sure if you every got the answer you were looking for. The standard holes that are pre-drilled for the pots will be the same size as the hold needed for a 5mm LED w/Bezel. The Bezel helps it fit into the same hole size. Just choose a drill layout that has an extra hole for your LED.
PS>Good luck getting an answer back from Blake, the only time I can get an answer back is if I send at least 3 consecutive emails in one day.
