This is going to be my first pedal build. I was thinking of building it on a breadboard first to tweak my values, and then once I'm set on the design wiring it up P2P in a MXR style enclosure. Is this a good strategy?
So far I've ordered a NKT275 spec'd for Rangemasters, and am now investigating the different options for parts/construction for my build. I kind of don't want to go with a kit and PCB/turret/Perf board construction, and want to keep it really clean. Just a single level knob, a LED, and a foot switch.
I'm going for a sound close to the Mid boost setting on the Keeley Java/Analog Man Beano, and plan on tweaking the input cap to hit that spot, and don't intend to utilize a tone control.
I plan on using a socket for the tranny in the pedal, so I can swap in and out different ge transistors for tweaking the design. I have the OC44 Keeley, and want to compare the NKT275, and AC128(or 7?) versions to it to see which I like best.
Also, I plan on wiring it up with a PNP tranny wired for NPN instead. What do I need to watch out for if anything?
Anybody have any good references/tips for wiring up such a pedal?
