the PCB schematic is here
https://farm3.staticflickr.com/2942/15141087990_3b53abf726_o.gif
to anyone who purchased a kit. install wire jumprer or 0 Ohm resistor in D4 D6. install the germanium diodes in D5 D7. be very careful to not break the glass when bending the leads of the germanium diodes. do not install D2 D3. pads SD1 and SD2 get soldered together and then jumpered to SDG. optionally you can add a switch here to connect SDG to the SD1 SD2 group. SB1 and SB2 is the second footswitch on the ibanez standard fuzz. the trimmer is there to adjust the volume of the tone bypass footswitch. be careful not to install the 5 pin 10K bussed resistor array backwards. pin 1 is marked on the resistor array and on the PCB. the most common mistake that can go wrong with this build is electro static discharge damage to the FET as a result of improper handling. you should have your anti-static grounding strap on your wrist from the time you take the FET out of the bag to the time you put the back plate on the pedal. after it is soldered you do not need to worry so much as the resistors will mostly protect the FET. if you do not have an anti static ground strap you can google how to make one or just touch the metal on the back of your computer while you are seated getting ready to solder. here is a cheap wrist strap you can buy. it will save you hours of debugging dead FET's. you need to connect it to your computer chassis or something that you know for a fact has the metal chassis connected to the third prong on the wall outlet. if you have a broken extension cord you can use that to attach the wrist strap.
http://www.amazon.com/Belkin-Anti-Static-Wrist-Adjustable-Grounding/dp/B00004Z5D1
here is a little trick to get a ground
http://cdn.instructables.com/FG2/ORBR/H0OIWS2X/FG2ORBRH0OIWS2X.LARGE.jpg
I use something like this
http://www.digikey.com/product-detail/en/09838/16-1158-ND/3043259
