skullservant wrote:Disaster Area/DMC might be ALL over this. Especially something as simple as that!
space6oy wrote:i don't think on/off can be controlled via midi. it isn't mentioned in the manual. far as clock though all you need's a Y cable from whatever midi out you're sending them.
Iommic Pope wrote:Skip, you rule. You hate people so much, you're willing to discredit all human progress, its awesome.
Ancient Astronaught wrote:Stereo true bypass looper box (1 footswitch [4dpdt can do it I believe] that turns on and off two independent loops) then add a midi tap tempo board and a midi splitter, it will be 6 jacks 2 footswitches and 2 midi outs. Leave em both on and run them through the stereo loops and you can turn em both on and off with one footswitch, and use the tap tempo to sync them both.
new05002 wrote:Ancient Astronaught wrote:Stereo true bypass looper box (1 footswitch [4dpdt can do it I believe] that turns on and off two independent loops) then add a midi tap tempo board and a midi splitter, it will be 6 jacks 2 footswitches and 2 midi outs. Leave em both on and run them through the stereo loops and you can turn em both on and off with one footswitch, and use the tap tempo to sync them both.
that seems like a metricfuckton of cable routing for what could be done with just 2 midi cables and a smarter microcontroller on a unit.
space6oy wrote:ah, i didn't read the chart, just the midi section and that wasn't mentioned.
Ancient Astronaught wrote:new05002 wrote:Ancient Astronaught wrote:Stereo true bypass looper box (1 footswitch [4dpdt can do it I believe] that turns on and off two independent loops) then add a midi tap tempo board and a midi splitter, it will be 6 jacks 2 footswitches and 2 midi outs. Leave em both on and run them through the stereo loops and you can turn em both on and off with one footswitch, and use the tap tempo to sync them both.
But it doesn't require much digital midi I/O knowledge to build and utilize.
Users browsing this forum: No registered users and 14 guests
