Quando Omni Flunkus Moritatisanfordandsonny wrote:guitars are hammers if you put some electrical tape on the handle so the blood doesn't make the hammer slippery so be it.
theavondon wrote:Logan 5 is rad too.
eatyourguitar wrote:the term ring modulator is supposed to be used to describe an effect with a diode ring and two inputs.
smallsnd/bigsnd wrote:eatyourguitar wrote:the term ring modulator is supposed to be used to describe an effect with a diode ring and two inputs.
yep. though when using a passive ring mod like the one you posted a pic of, you may additionally need a gain stage or boost in and out. in so that you're feeding the ring mod with an acceptable signal level to work with, out so that you have enough signal to combat the losses of using a passive device. then again, you may not need that stuff... just painting the entire picture.
Users browsing this forum: Google [Bot] and 17 guests
