non-tap tempo gyroscope
Moderator: autopilot
Postby autopilot » Mon Dec 03, 2012 10:04 pm
Same as the tap tempo gyroscope*, except that the rate/speed is set via the knob or the expression (will take trs expression or 5v cv). This version also has an auxiliar for the range so you can dial small sweeps or get the full sweep (while the older 5 knobber the range was more limited), also the input was redesigned so it can handle hotter signals without clipping and be bass friendly.
*The tap tempo gyroscope now comes with a toggle to select if the rate is tap tempo (ratio knob sets the multipliers) or standard rate (ratio knob sets the speed)
autopilot
Return to Copilot fx
Users browsing this forum: No registered users and 14 guests
